Suspension too soft
camelman
I recently bought a 1997 Ford Ranger 5-speed xlt with the 2.3 and 175,000 miles. I replaced the original shocks because they were shot. However, there wasn't really any improvement in the ride. It is still way too soft and has entirely too much body roll.
I installed cheap Monro-matic shocks from O'Reilly's, so that could be the reason for the mushy ride. However, the springs also seem too soft. I can shake the entire truck up and down about 5 inches with one hand, and it only take a couple pulls on the fender to do that.
I plan on installing a rear sway bar to help with the body roll, but I think the front and rear springs are too soft. It seems that every related post I find is about the ride being too STIFF, not too soft. Any thoughts on how to stiffen the ride up? Thoughts on the shocks I bought?
The truck has axle code 86 (open 7.5" 3.73) with the three-pack leaf springs. All springs (front and rear) appear unbroken.
Thanks,
Camelman
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
Probably just need new springs. Shocks absorbers are for absorbing shocks and dampening the bouncing motion, the springs support the vehicle itself. I have a 1999 and have done a T-Bar crank (front was 4" lower than the rear original springs) and replaced the rear springs with an added leaf. Springs don't last forever. I put Monroe Sensatrac or whatever they're called in as well and eventual had to deal with the springs. Kinda nice taking off ramps without feeling like I'll roll over now.
camelman
Thanks for the reply. That rolling feeling is unnerving on the twisty mountain roads in CA. It seems that leaf springs will be less resistant to loads as they flatten, so I will probably get complete new spring packs. Any thoughts on the 3/1 (1250 lb) versus 4/1 (Heavy Duty) units found here:
http://www.sdtrucksprings.com/index.php?main_page=advanced_search_result&inc_subcat=1&categories_id=681&year_select=1997&make_select=622&model_select=8219&x=96&y=13
I've seen posts that increasing preload on the torsion bars will increase front end stiffness and ride height. Can I rely on a t-bar crank to restore stock ride height, or is there a benefit in replacing the old coils? I'm assuming my truck has sagged over the last 175k miles.
Thanks,
Camelman
rangerbum
30
Kalispell, Montana
2.8l
Your truck doesn't have torsion bars. Rangers up to 97 had I beam suspensions, using coil springs only. In 98 they began using A-arms with either coils or torsion bars.
You'll need to get new springs to get your ride height and quality back. I'd get a set for an extended cab, 2wd, 4.0 ranger. Those will have a stiffer spring rate to accommodate the added weight.
cvar
19
Mazda
4.0L V6
I installed the HD springs and I really like the added stiffness, extra load capacity, and the added rear height. See http://imgur.com/a/WpQR8 <== CLICK
But to reduce body roll, you might want to invest in a sway-bar, esp. one that's larger diameter than stock.
camelman
CVAR, thanks for the link, that's a great writeup. Are you happy with the springs you purchased, and did they come with everything needed for a spring swap? I intend on replacing my springs, shackles, u-bolts and spring/shackle bolts. The hangers look fine on my truck.
A swaybar is definitely in my future. I need to tow a trailer somewhat often, and don't want it swaying around on me. My truck didn't come with a swaybar from the factory... I'm going to wait on the front springs until I've rebuilt the rear.
Those shocks are shit, but they won't cause the ride to be mushy. Shocks only dampen vibrations caused by a stiff ride. Shocks cannot make a ride mushy, they can make it shitty, or they can do what mine do and let it set up a vibration that shakes the wheel all over when you get on a patch of road that is just right.
cvar
19
Mazda
4.0L V6
Thanks. Yes, I'm very happy. That spring kit included absolutely everything, even all the Grade-8 washers. It all bolted in easily. They sell complete kits and partial too. I already had a sway bar, as you can see in photos.
Like this: http://www.autoandtrucksprings.com/products/Ford_RANGER_HEAVY_DUTY_Leaf_Spring_Assembly_Kit_Complete_INCLUDES_8_ROUND_U_BOLTS_fits_2_1_2_Wide_Leaf_Spring_SHIPPING_COST_FOR_SPRINGS_ONLY-2171-157.html
