flyingbrick
- Mar 11, 2008
- 3
- Age
- 34
- Winnipeg, MB, CA
- Ford
- Engine Size
- 3.0
Yeah just keep the other fuse as a spare, or toss it on eBay to make something back.so i am pretty sure I am going to make my purchase tonight
sub
amp
8g wiring kit
150A AFS fuse (2;; keep one for extra?)
gonna get mdf, drywall screws, L-brackets (for securing to my cab) can i also use L brackets to brace inside? was going to use small blocks of wood in the corners too for bracing, wood glue (think we have some in the basement), silicon sealant (have some pretty sure too... regular caulking works?), what grit sand paper to sand the whole box after done? and was going to see if a local hardware shop has terminal cups.
do i need anything else?
You can use the L brackets to brace inside, but you'd be better off making your cuts as close to perfect as you can, and using the glue or silicone and screws to keep the box together.(mine box has no bracing) Silicone/caulking more less are the same thing. I use about 80-100 grit for sanding excess glue, and whatnot. If you have a radio shack near by they'll have terminal cups, the only other thing you'll need is terminals for the inside of the cup, and speaker wire for inside the box too 14 or 12 gauge will be fine.
