Mike828
- Aug 8, 2009
- 0
- North Carolina
- Ford
- Engine Size
- 4.0
1987 Bronco II.
Put new-used '87 2.9 motor in it last winter. Used '92 ecu to remove EGR.
Put in new-
in-tank fuel pump/sender/sock
fuel filter
coolant temp sensor
map sensor
oil pressure sensor
air charge sensor
plugs and wires
'rebuilt' the injectors
clutch/pressure plate/flywheel
Ran great until 2 weeks ago. Wouldn't rev over about 2200 rpm. Got code 14, Ignition pickup was erratic, replaced TFI ignition module with used one that tested good 3 times and ran great for a week.
then it started acting funny, loosing a little power right after shifting (manual trans). This has gotten worse and worse to the point I need to drop to second gear to get up a hill I used to have no trouble with in 3rd or 4th.
I've tried to pull codes, there aren't any.
Grounds are good.
Compression is 150-170
Fuel pressure is 40psi key on engine off and drops to 32 engine on and rises slightly with throttle then settles.
I went ahead and got a new fuel filter, cap, rotor, plugs, ignition pick up, TFI module, idle air control valve, throttle position sensor and O2 sensor. No help.
It definitely sounds funny when driving. Like it's out of time, sort of 'glugging' and hard to describe, but idles fines.
It is timed at 10 degrees BTDC with the SPOUT removed but when i watch it with a timing light, every few seconds I don't see the mark on the pulley.
Both cats and muffler I believe were replaced by the previous owner who didn't change the oil, ever, I think. I found a LOT of carbon and goo in old engine that didn't have any oil pressure.
Anybody got ideas? I'm starting to wonder if the cats are clogged or the ECU is having issues. It idles fine. Just no power when I try to move it.
Put in new-
fuel filter
coolant temp sensor
map sensor
oil pressure sensor
air charge sensor
plugs and wires
Grounds are good.
