Stripped screw holes for rear license plate frame in rear step bumper pad.
29
San Marcos, Texas
B3000
Go to Harbor Freight on get a robot gun and some POM rivets. They are made of plastic and have good holding power. Easy to drill out when needed.
Ray
dang auto correct....rivet gun
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
I got longer 1/4” bolts, put through the backside of bumper & a drop of loctite with a nut, bolt stays put & a 2nd nut (nylon locking) retains the plate.
Edit: as I was typing my reply @snoranger responded with the same idea.
They say great minds think alike.... apparently so do we.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,767
Wellford, SC
6"
Ooh. Another cool idea;
All-thread with nuts and washers, straight through to the front bumper. Then it will hold the front license plate, too.
racsan
4,512
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
on my front plate I used self-drilling screws, then ohio dropped the front plate requirement and it got tossed in the scrap corner with the other 2 vehicle front plates.
1990RangerinSK
1,312
Saskatchewan, Canada
When I find that "screwdriver operator" I'm gunna give him a piece of my mind !!! :)
Yes I've thought about the nut and bolt idea. But every year I need to pull off the license plate to scrape the old sticker off (California). A little inconvenient but do-able. Thanks.
We had yearly stickers here for 30 some odd years. I think they did away with them in 2013 or so, but they started in 1977. We all just put the new sticker over top of the old one.
Fredness
28
Sasquatch Country!
Ford Sport Trac
4.0L SOHC
Find the square replacement inserts at your local auto parts store - use a drill/Dremel/razor knife to open the hole JUST large enough to fit the insert.
WHEN the insert goes bad, pop it out and insert a new one.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Take a small plastic wall anchor and push it into the enlarged hole, and remount the license plate with the original screws.
ericbphoto
16,767
Wellford, SC
6"
That sounds like a winner.
Ranger850
Doesn't get Sarcasm . . .
4,699
Tallahassee Florida
Stock 2"
Stock
Stick a toothpick or match stem in the hole and put the screw in.
I use the cut off pieces of plastic zip ties. shove one or two in there and they take up the slack, and the screw threads the plastic.
saxtech
37
Huntington Beach, California
Ford Ranger XLT
3.0 Flex Fuel
I like that. Thanks Grumpaw - I'm sure I can find some of those drywall anchors in the garage. I was going to buy a Rivnut Tool but started thinking, why spend $25.00 to fix this silly license plate screw hole and I probably would never use the Rivnut Tool again....
Ramcharger90
1,708
N/A na
306, Bcam,
47687
Drill the holes out and put these in.
Bgunner
1,097
Western Mass.
Ford/Ranger XLT
225/70/R15
We have to get new stickers every 2 years here and the only time I scrape them off is when they get really built up, every 10 years or more. We just put the new one over the old after a quick wipe with Rubbing Alcohol to make sure it adheres properly. I do mine in the middle of winter and still don't have issues with it adhering to the plate.
@saxtech Why do you need to scrape every year? Is it a Cali law that you cant just put the new one on over the old?
saxtech
37
Ford Ranger XLT
3.0 Flex Fuel
I learned long ago that the thicker these stickers get, the easier it is for a thief to scrape the stack off without damaging the top sticker, and re-gluing the stack to their license plate when they don't want to pay for a new registration sticker for their car. Cops think you are current on your registration if you are displaying the currently proper color sticker so you won't get pulled over with an expired sticker.... I even go one step farther and not only do I keep only one sticker on my plate, but once I have the new sticker stuck well onto my plate, I take a razor blade and put an "X" into the sticker and maybe a few more cuts. This way, if a thief tries to steal the sticker, it deters them once it starts coming apart in pieces or hopefully they see the cuts before they even attempt to remove it...... Just an old habit I have. Plus, it really does look tacky when a car has many years of stickers stacked on top of each other.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
That is a really good idea. Stealing it.
