Stoutness of the 7.5?
Soledad
2.3L Duratec
I just picked up a 2003 XL 2.3L 2wd 5-spd manual regular cab and am currently learning the truck and fixing everything that needs fixing. It's got 130,430 miles on it and it's needing some definite TLC.
Any way, I've learned that it's got the 7.5 axle with 3.73's and open diff.
I've been contemplating on putting in a V8 & auto trans and was wondering if the 7.5 could handle the power increase? I'm not looking to take the truck drag racing or anything nor would it be used exclusively for rock crawling and etc. It would be used about 95% on street as a parts/home/trash runner, 5% light offroading and 1% generally just messing around.
The Explorer V8 I throw in it would be upgraded to make somewhere near 300HP (no clue on tq). I'm not looking for big numbers.
Oh and I'll be putting 31x10.5x15's tires on it too.
Could a 7.5 handle that or is it a must to move up to the Ranger 8.8 or Explorer 8.8? If I had any :icon_welder: skills I'd just go with an Explorer 8.8 but my little 120v Harbor Freight flux core welder probably can't put out enough heat to weld the spring perches and shock mounts and I know of no one or any welding shops around here to do the job.
Anyone run a V8 or high HP engine and 7.5 axle and live to tell the tale?
Right now I'm just looking into my options but the V8 will happen.
Thanks!
jeremysdad
ASE Certified Tech
I had a 2002 that I bought new. 3.0 5 spd w a 7.5 rear. Spider gear and a retainer fragged in about a year.
Personally, I would find an 8.8 from a jy donor. Find one in a ranger and it will be a straight swap.
Good luck!
17,879
SW Iowa
What are you planning for power with your proposed V8 swap?
Ring gear and spider gears are all you are really gaining with a 28 spline 8.8.
Soledad
2.3L Duratec
Eh, I'm not looking for big power. I figure up to about 300HP from a '99-'01 Explorer 302.
I figure the higher TQ/HP and larger 31x10.5x15 tires may put the 7.5 beyond what it's capable of.
I just don't know "exactly" what it's capable of.
17,879
SW Iowa
Ford became nervous putting a 200hp V8 in front of it for the 1986 Ford Mustang, the first year they got a 28 spline 8.8.
And a foxbody is both lighter than your truck and packs much smaller tires.
Soledad
2.3L Duratec
Doh!! Now that I understand.
Do you think a 28 spline 8.8 out of a Ranger would handle it or am I looking at a definite Explorer 8.8 swap?
17,879
SW Iowa
If you are going really use that power I would go Ex 31 spline. If you want to add disk brakes I would go Ex 31 spline so you would kill two birds with one stone.
If you do what you say you are going to do a 28 spline would probably be fine.
My 130k mile 7.5 never whimpered with me throwing my 200ish hp V8 at it though, they were together for a year. I mainly got my 8.8 for the limited slip... and I had it before I got the 302 just not installed.
Soledad
2.3L Duratec
Thanks for the insight everyone. I'll go with an Explorer 8.8 and try and find someone to weld the spring perches and shock mounts.
Well, actually, that brings me to another somewhat related question; Could the 120V Harbor Freight flux core welder actually provide enough heat to weld on the perches and mounts properly? Exhaust is one thing (which I bought it for) but axle tubes are a whole other ball game.
You know what, I retract that question. I'm not good enough yet to weld something so critical. I'll find a place to do it.
BLOODBANE
19
Canon City, CO
FORDFORD
347, 4.oh
If you can find a FX4 Ranger, they came with 31 spline 8.8. BUT, tough to find... I ran a 7.5 for a little bit behind my first 302 in my 84.....
I did wheel it a little bit (Im not hard on equipment though). I had 32's on it in this pic with a Lock-Right. It held up, but like i said, I wasnt hard on the stupid pedal....
Soledad
2.3L Duratec
Thanks Bloodbane. I'm lovin' that pic! Makes me miss my ATV'ing and 4wd'ing days when I lived in Colorado a few years ago.
Because this truck is 2wd, even with a locker I still wouldn't take it to places like that. Only level 1, 2 and maybe 3 trails for this thing. I haven't been wheeling here in the Cascades or Wenatchees yet so I'm not entirely sure what to expect.
I think I actually found a place selling a FX4 Ranger 31-spline 8.8 but the price is almost triple what a regular 8.8 goes for. So it would seem they know what they have.
In the long run though I think the Exp 31 8.8 will be the way to go. It gives me a little head room in case I want to up the power or get more bold in where I take it.
17,879
SW Iowa
And if you ever need a shaft Explorer ones are much easier to find than FX4 ones. And if you want anything other than a Torsen you will have to get an entire carrier.
monstermazda
Mazda
3.0l
You can put a 351w roller motor in there with the 99-01 302 heads and electric stuff it make the computer think it's a 302 but it's a 351 they both had the same deck hight if I remember correctly
Sent from my SAMSUNG-SM-G870A using Tapatalk
pjtoledo
2,968
Toledo Ohio
Fords
3.0 2.3
302 is 8.206, 351 is 9.48 or 9.503 early vs late.
17,879
SW Iowa
don4331
1,346
Calgary, AB
5.3
I'm going to question the fox body 'stang being lighter than Ranger/narrower tires. :)
The '95 Cobra I got my rims off crossed the scales @ 3,458lbs; 1,522 of that on rear axle. My Ranger tips scales @ 3,549lbs; 1,477 of that on rear axle. (Both weights are with me in driver's seat). So, Mustang is 50lb heavier on rear axle and my Ranger has a hard tonneau. Without tonneau, Ranger is lighter overall than Mustang and only has ~80% of weight on rear wheels that the car does.
Mustang had 245/45R17s, Ranger 235/60R15s. Just saying. :)
You don't have to do any welding. Order a set of DJM Suspension lowering blocks for an F-150, and use them to put the spring perches on top (opposite of how they were intended to be used).
The 7.5" in my '82 'Stang ('69 351W 4bbl engine) lived largely because I simply couldn't hook up well enough to break anything, but then again it had 3.08 gears. Your 7.5" probably has 4.10s...
