Steering
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Sounds like you may have to lower your radius arms down a bit.
shadow88
CLOQUET MN
FORD
Any suggestions on how much? Or is there anything else I should look for first?
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
That your axle beams (the rectangular section where your radius arms attach) are square (level) with the ground (not tilted forward or back). This should set you up for about 5° caster, which you can then adjust +/- 2° or so with the bushings.
Also, make sure the steering is able to move freely from lock-to-lock with both wheels off the ground (check that nothing's binding within the steering gear, column, or linkage)
