Steering bind after 3" Body Lift?
jd_21
Hey Guys, just installed my new body bushings and my 3" body lift this weekend and now when i turn to the left it seems as of something is binding inside the the steering column. any thoughts on this problem anyone?
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
Did you also install the steering shaft extention? If you didn't, that is your problem.
mhughes165
9
302
jd_21
yes the shaft extender is installed
BlackBII
Ranger Custom
Truck of Month
982
UT
Maybe its not long enough
jd_21
it came with the kit, why would they supply sumthiig at isn't long enough
jd_21
if this helps it seems as if for some reason it is somewhat binding up near the steering wheel.
pillen140
45
winston-salem, NC
it should say in your instructions, you may have to modify the hole in the firewall a little.
jd_21
nope never said anything in the instructions about that
pillen140
45
winston-salem, NC
you may have to "hog out" the shaft hole.... if thats where its binding. it may feel like the wheel binding because its all attached(obviously)
jd_21
it is doing it right behind the steering wheel tho, like it makes a noise too
