steering and upgrades
HIPCHIP
Woodland, Ca
90 Ranger XLT 4X4 with 4.0 L V-6. 100K on it and everything is bone stock and original.
I read a review on this truck and it talked about how the steering was a bit mushy and slow, and I have noticed this. My other veh is a Dodge Magnum R/T and it handles pretty quickly compared to the Ranger. Just wondering if there is something to do to the Ranger to make the steering better or is this something I just need to get used to?
The suspension, including the shocks, as far as I know are 18 years old and completely stock. How good were the stock shocks? Haven't done much off-roading yet, and the suspension feels pretty stiff on the highway, so don't know if I need to upgrade the shocks or not, or if this would help the wallowing?
Will a steering stabilizer help?
mhughes165
9
302
replacing aged components will always help, if all the suspension is original i would start there, and a steering stabilizer always helps. the reasoning for the steering bein "mushy" is the pump that ford used for the power steering, if u can run a upgraded pump it will make for a much smoother and more responsive steering system.
there was a thread somewhere here about someone that upgraded there steering pump, and the practice can be done for most other rangers aswell
silveranger93
You're comparing an 18 year old RCB steering setup to a few year old R&P setup. You're not going to get the quickness or the 'tight' feel of rack and pinion with an RCB setup. The only improvement you can really do is to replace any wornout parts on your Ranger. This won't make it feel like your Magnum, but it may tighten it up a little. IMO the steering setup in those Magnums is pretty darn nice.
HIPCHIP
Woodland, Ca
I realize the steering on a low riding new Magnum will never be duplicated by a stock 18 year old 4X4 truck, but was just stating that is what I'm used to and was wondering if there had been a fix for this as it appeared to be a problem with the truck. It's just a weird feeling driving down the road and the steering is mushy. As far as I can tell everything is pretty tight on the steering and suspension. I just replaced the power steering lines, so that's new. As I go along I will replace more and more, I'm sure, just not enough $ to do everything I'd like.
Dan'o :}
silveranger93
As long as nothing is worn out in the steering or suspension, there is nothing you can do to make it feel any different. The only component that will get rid of the 'mushy' feeling (if nothing is worn out) would be the actual steering gear itself and to a slight extent the pump. The valving in the steering gear is what gives the steernig ratio (quickness), the on-center feel and the amount of assist. The mushy feeling is caused by the valving that Ford chose for the truck. It sucks but there isn't much you can do about it.
HIPCHIP
Woodland, Ca
Well, it's nothing I can't get used to I guess. I didn't think there was a quick, easy, and cheap fix for it, but I could hope. If I was racing and stuff I'd worry about it, but as I'm just playing I'll just make sure I'm aware of it and go from there.
Thanks for the info.
silveranger93
Sorry I couldn't give you a quick and simple fix. I really wish there was one. I'm not really sure what (or even if) Ford was thinking when they approved that gear, it's abolutely terrible.
It probably bothers me a lot more than it bothers you. I work for an OEM steering supplier, so I'm very critical of the steering characteristics of a vehicle. I find myself evaluating the steering on any car I drive, I just can't get away from it!:rolleyes:
HIPCHIP
Woodland, Ca
Not a problem. I've always been a Dodge/Plymouth guy, and my father-in-law was a Ford guy, so we always used to tease each other, so I guess this just justifys my beliefs a little more (LOL).:scare::taunt:
silveranger93
Haha. I'm a huge Mopar guy, my daily driver/tow rig is a '97 Ram and I love that thing. It just happens I keep ending up with Ranger's, but I do love them even with all their quirks.
HIPCHIP
Woodland, Ca
I went to elementary school with Dick Landy's kid, so was kind of raised on Mopars. Grandparents and parents drove Mopar, the military used Mopar, and my job used Mopar, so it was inevitable. When I was a kid my neighbors worked for the Chevy plant, so in my neck of the woods it was Mopar or Chevy. I like my little Ford though, so guess I'm a convertin :icon_surprised:
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
The TTB style suspension , even when new , has always been called vague at best. As long as everything is in good working order, it is what it is.
HIPCHIP
Woodland, Ca
OK, sounds good for now. I can see my buds bugging me to do an SAS in the future.(LOL)
Since I'm planning on taking it slow, it should be good enough for now.
Dan'o ;}
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
I should clarify my statement about TTB suspensions. I like the TTB, it works well when set up properly, just the steering "feel" is vague at best.
HIPCHIP
Woodland, Ca
Is there a way to check if the ball joints are worn out?
I know on the shocks for cars it's bounce the car and it's supposed to bounce 1 1/2 times, but not sure on the truck. I imagine the shocks are the stockers and as such are 18 years old. I'll probably upgrade them after my first off-road trek (LOL)
Suffield, Ohio
SOHC 4.0L
LT265/75/R16
I have the same problem with my 94. Our fam. also has a 2000 Dakota with unbelievable steering. Handles like a car
