steam cleaning
dru
4
Pacific
anyone know how the simoniz steam cleaner or comparable brands work at cleaning carpets and upholstery? do they just spray steam loosen the grit grime and still need to be vacuumed ? or do they suck the crap up at the same time its steaming the carpet?
i spilled a large Coke all over the seats and carpet and dont know if its worth my time to try those spray on vacuum off chemicals with the sticky coke. steam cleaning seems like the best method.
thanks
dogboy
14
Enumclaw/ Carbonado, WA
'93
Either a steam cleaner, or just a regular carpet cleaner would probably be best. When I got my truck, I just rented one of the Rug Doctor (I think that is the brand) machines from Safeway. It was 25 bucks for a day if I recall, and it did wonders!!
I would think a steam cleaner works the same way, but all the carpet cleaning machins that I have seen spray either the steam or cleaner or what ever they use and then the vacuum part is directly behind the sprayer, so it then vaccums all the crap up.
My interior looked somewhat clean (seats anyway) and it was really amazing how much crap it took out of them.
One suggestion though, I would take the carpet out before doing anything like this. The Coke probably soaked all the way though, so by taking the carpet out, you are able to get to the backing, and well as make it faster for the carpet to dry.
It really isn't too difficult to take out the carpet either. Takes me maybe 30-45 minutes at most to do it now (granted I've had it out 4 or 5 times due to mud water soaking into it). Just take the seats out (4-6 bolts depending on the seat) and then the trim pieces around the floor, and it comes right out. It will also make getting to the carpet easier as well, becuase you are not having to climb around in the truck.
  • Like
Reactions: dru
dru
4
Pacific
i just called around to some detail shops. got all of the carpet and upholstery steam cleaned for $50. its like new.
i went to Ace hardware to rent one of their machines $19 for 24 hours but the damn cleaning agents were more than the rental cost and i couldnt decide which cleaners to buy.
im going to look into buying a little steam cleaner that vacuums at the same time for future cleanings. the Bissel Green Machine looks promising.
thanks
