twinturbopantera
- Jul 31, 2008
- 0
- Peoria
- Ranger
- My credo
- You can never have too many modifications.
The Sandersons will work. Just finished a swap into a 99 2wd. The driver side fits great. Though I did use a steering rod from a 4.6 explorer to get a little more clearance and dented a couple tubes. Passenger side hits the frame and mount for the a-arm. But not much. Made a small notch in corner of frame for clearance and welded up and dented the tubes. Also to make hookup easier, I removed the flanges and welded on 45 deg angle tubes with a different flange. I did not have issues with mounting plate for engine as I could not use that type of mount with the 2wd. I used 95 F150 mounts and box tube welded to the crossmenber for engine mounts. They work very well.
