Spring Lock Fuel Line Repair
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
So, in the process of pulling my engine to change the oil pump, I became a little... "frustrated" with my fuel lines, and out came the cable cutters. Damn spring locks wouldn't release, even though I had them disconnected back in July.
I cut both lines on pump side of the spring lock connectors. Looking around for new fittings/repair kits this morning, I see that my options are downright confusing.
Anyone have any suggestions on how to repair the lines I cut in anger? I will need something to fit the cut off nylon lines and adapt back to the spring lock fittings.
A little disappointed with myself on this one, but I was so p*ssed off at that point that I didn't care what I had to cut, that SOB was coming out.
ericbphoto
Overlander in development
16,605
Wellford, SC
6"
Seems like I found some repair ends for that a while ago. They had a barb for the hose to fit onto and the spring lock to go to the filter or whatever. The barb fit really tight. I think heat helped. Don’t remember where I got them from. Seems like it was Advance auto or Oreillys.
or maybe I re-used the original fittings after cutting the hose off of them.
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Someone posted a fuel line repair trick on here a few weeks ago I believe. I think they reused the fittings. They used a flaring tool to grip the line and push the fitting back into the line. I can't seem to find it doing a search... but you make have better luck
Bird76Mojo
1,265
IL
I found several styles in under a minute on Google, but I'm not sure which style you need. Post a pic maybe?
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I saw that same thread.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
He used a caulk gun as a press.
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That is exactly what it was... a caulk gun. I was half right... he used the flaring tool clamp to hold the line... then put that it the caulk gun to do the pushing.
