spongy brakes after disk break swap
Kyler Skovbo
oregon
ford ranger
I recently completed a ford 8.8 swap in my 91 ranger. it has the disk breaks but I'm having an issue with my pedal having no response until its a ways into its stroke. i was thinking my stock mater cylinder isn't pushing enough fluid to cope with the new calipers, does that sound right or is there other things i should check out.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,535
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
My guess is you still have air in the system. Disc brakes require no adjustments that cause a low pedal like drum brakes would. An improper sized master wouldn't cause a low pedal... it would result in excessive pedal pressure having to be used.
A long shot perhaps... but I've seen where calipers were installed on the wrong side and the bleeders are actually on the bottom which allows air to be trapped in the caliper.
I would suggest looking over every connection to ensure you have no leaks and give them another complete bleeding.
rubydist
865
Denver
Ford Ranger FX4
You still have air in the system. Keep bleeding until it firms up.
sgtsandman
Aircraft Fuel Tank Diver
12,739
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Agreed, there is still air in the system somewhere.
Kyler Skovbo
oregon
ford ranger
i took a look at it last night and realized that when i put the calipers on the axle was out of the truck and flipped around so the bleeders were in fact on the bottom.
Uncle Gump
Token Old Guy
13,535
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
There ya go... not the first time I've seen that happen.
scotts90ranger
4,445
Dayton Oregon
2.3 Turbo
That would do it for sure, the explorer 8.8 disc brake axle in my '90 works perfect with all stock components...
17,953
SW Iowa
My '85 hydraulics worked great with my disk brake 8.8 until I added the dual piston front calipers.
