Speedometer gear headache
ratdude747
22
Madison, IN
215/70R15
I changed tires this weekend, and as a result of them being a tad small (215/65R15 vs the old 215/70R15), my speedo/odo is also off.
Despite being a 1995, I found that my VSS has a cable-style gear on it:
(that's ATF, not blood).
Despite being green, it's actually 16 teeth.
However, when I run the numbers, I need a 16.48 tooth gear. That rounds back to 16... but it's right on the line. According to tire size ratios and some empiriacal data, I'm reading 3.3% too fast.
I'm not in the budget for a speedo healer ($220, no thanks). Is 3.3% close enough to be OK? Or do I need different tires. The latter isn't so good, as I bought nice tires; they're Continental Control Contact Tour AS's (I know, car tire, but I don't offroad and they ride really well).
What to do? :icon_confused:
Spott
21
SE Idaho
If that's the nearest solution, then it must be "good enough". You'll have to determine for yourself if you can live with that.
The only other alternative I can think of is to see if there are other options for speedo drive gears, such that a different drive/driven gear combination might get you closer. For example, in my '88 I could use a 6-tooth ivory-colored or 7-tooth burgundy-colored drive gear, in combination with any of the common driven gears.
ratdude747
22
Madison, IN
215/70R15
Ah the spiral gears. I'm sure for the 4r44e there is but I worry such a change would make all the speedo gears gears out of range. I'll look into it.
