Sound deadining
Terry
19
Gardnerville, Nevada
I finished my basic install of my system a few weeks ago. I have 6 x 9 Alpines in the stock rear location. I put some pioneer 4" speakers in the dash. I am hunting for a shallow sub and amp to finish it out. Im not so happy that the rear stock location speakers as that they loose sound as that they are below the top seat level. I dont know if I will move them from there or not. I have my door panels out. I want to put sound deadining in the panels and floor. How do you do the doors so water does not get soaked into the deadining material. Where did you put your sound deadining in your truck also did you use any spray form?
TIA
Rockstar04
Northern Illinois
For any location that could get wet (Doors, under your carpet/vinyl) I would suggest a heavy rubber or loaded vinyl type of sound deadening, its waterproof and some of the best sound deadening for automotive use.
This stuff, thick, heavy, and normally foil lined.
Terry
19
What is the name of it and where can I buy it?
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Rockstar04
Northern Illinois
Ya, actual sound deadening is very expensive, so I would give Shane's Suggestion a shot if this you are on a budget, otherwise Google dynmat, or stinger sound deadening.
tylork92
elemental designs makes one of the less expensive optioned. they also have a liquid version (what i used) that works well also.
Terry
19
I wonder if Henerys roof patch would work as good as the paint on type on this web site? At any rate I have options for materials to use for the sound proofing. Where sould I put the sound deadening material? I believe the carpet is glued to the floor so that area will probably not get sound proofing.
03Fx4MN
Lake Elmo, MN / Jacksonville, NC
I got some Fat Mat off ebay 100 sq feet for 100 search it my truck has the floor doors and back wall and it really cut the road noise out by I'd say 75%
Tominator
24
Cahokia, Il.
5.0 S-Trim 450HP
Back when I did mine, Dynomat was the only real choice and yep, it was expensive!
Sound deadening is a great way to improve not only the sound from your speakers, but like someone said, it cuts the interior noise drastically.
In my truck, and remember it is a 'high end' system you can barely tell there is anything special going on in the cab. But get in, shut the door and hang on! The crystal clear highs and lows combined with the ability to 'thump' with the best systems only dreamed about in a DD and all this would be a waste of money without some kind of sound deadning material.
Don't forget the headliner.
kryptonitecb
19
Fort Worth, TX
For the installation don't just put a layer of the stuff everywhere. You want to cut the insulation into sections and put it on until the panel your working on doesn't ting when you tap it anymore. As for the door, dynamat can get wet, the material doesn't absorb water like the stock jute does. Don't forget to seal everything while your at it, a layer if mass loaded vinyl on everything will help too.
Sent from the road while ignoring traffic
