Something rolling around in drive shaft?
ServerGuy
After a bit of diagnosis I've come up with the following noise seeming to come from the rear of the rear driveshaft (see video below)
Any ideas?
https://youtu.be/XyhHzjnZREs
Remove drive shaft and shake vigorously. That will tell you the noise is there.
If that is it, get a new shaft.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
^ yup
Might also be something in your brake drum. I had one come apart and all the springs and little brackets where rolling around in it. Does seem to be somewhat in tune with the D/S though, but unfortunately removal of some parts is the next step.
