Someone Shot at this Ranger
projectRanger93
314
Los Angeles, CA
Ranger STX
235/75-R15
Found this on Pick Your Part at the Sun Valley, CA location. The owner must've had a bad day...
39297
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I've had several "shootin cars" over the years...
rusty ol ranger
2.9 Mafia-Don
7,702
Michigan
177 CID
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
They look like some decent sized holes and kinda deformed gotta be a .45?
My 9mm and .357 make pretty clean small holes through a car body like a sheet metal punch.
4.0blue98
I don't feel tardy...
705
Frederick, Maryland
4.0 OHV
Round
It was like that when I found it.
Must be the fabled Bonnie and Clyde edition. Probably worth a bunch.
8thTon
--- Banned ---
806
Pennsylvania
If it has a 2.9 the driver probably couldn’t tell. Is that tapping a little louder today?
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
Jeremy was the first person to be a big fan of tomatoes in the morning before the engines were all over the place on the road to get the parts from catalogs and other inappropriately made things.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Son.
Just for that, I'm going to chain on to a running 3.0 and rip the crank straight out of the mains.
snoranger
Professional money waster
ASE Certified Tech
13,729
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
rusty ol ranger
2.9 Mafia-Don
7,702
Michigan
177 CID
Bullet cant catch a 2.9.
8thTon
--- Banned ---
806
Pennsylvania
Someone was trying to put it out of its misery? Either it was a 2.9, or it has a manual trans and they tried bleeding the clutch 47 times with no success.
8thTon
--- Banned ---
806
Pennsylvania
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Looks purdy! Are you going to add some sort of lubrication system for the valve train to make up for the one those “German Engineers” forgot? :yahoo:
Already was running a melling 328 high volume oil pump, and have an electric scavenge pump on hand to go between the return side of the turbo and oil cooler. Pump sits at lowest point of oil system, and I have the wiring done to the megasquirt to run it before the engine cranks. So in KOEO, you'll be able to prime the oil system every time the engine is started.
New cam bearings are modified with a bypass oil passage in them, in the event a cam bearing decides to spin
Oil passages were chamfered to Pruett spec, and free floating rockers should help move a lot more oil across the top end.
Lifter choice was for FE block APUs to diminish potential lifter failure due to oil starvation... Which, I don't think I'll have an issue with.
Damn near dry sumped the thing, but couldn't track down a Benz to rob the dry sump system out of.
