saxtech
- Oct 13, 2015
- 37
- Huntington Beach, California
- Ford Ranger XLT
- Engine Type
- 3.0 V6
- Engine Size
- 3.0 Flex Fuel
- 2WD / 4WD
- 2WD
So where do I start ? It's starting to sound overwhelming.The dash light bulb should come on whether the system or button works or not. When you first turn the truck to run position all the warning lights come on specifically to test that the bulbs work, and for no other reason and in no way correlate to that systems status or functionality. Just tests bulbs...
So as improbable as it is, I think you have two problems.
Even some inexpensive scanners that run KOER tests will actually test the od button. My cheapo 20 dollar ancel 310 even does this. You turn the engine on, start the test, turn the wheel a few times, tap the brakes a few times, and press the od button a few times. If the od button failed it will tell you at the end of the test. (Of course it's only saying the PCM got no signal for the overdrive, doesn't pinpoint the issue).
So
Should I "first" tear the dash apart to change the bulb ? Buy a scanner ? Or check a fuse ?
Is it impossible that it could be something as simple as a fuse ? If so, what number fuse should I check ?
