As I said in the original post, I knew there would be more vibration. But, should the engine bounce up and down? I should have said "to that degree?".
O.K. A few years ago, I bought a car where the previous owner had tried to remove the harmonic balancer without using a wheel puller and the engine bounced up and down and vibrated to almost a thump when reved up. After I replaced the harmonic balancer, all of this went away. This Ranger feels exactly the same. This engine has been sitting for years and just recently fired up. The harmonic balancer came off a 1970 351C. The running engine itself is a 1972 351C CJ. I was just wondering if there are any differences in them, or maybe the harmonic balancer was damaged before I bought it. I did not have it running before, so the only comparison I can make is to a 5.0 with cushioned mounts. This 351C seems to bounce up and down as it is reved up just like the harmonic balancer is out of wack. But, if this seems normal, I can live with it. I was just concerned that if there was a balance problem, it would damage the main bearings.
