Solar powered?
Bryotch
Ok so I've had this issue a while but haven't bothered with it since it's been warm. All winter long my truck had problems starting. As soon as it warmed up I didn't seem to have any issues EXCEPT, when it's cloudy or rainy and less than 75 degrees or so. Fuel pressure is good, turns over fine. and even tries to fire once in a while. One thing I've noticed is 80% of the time it does this it smells like its flooded. The only things I haven't really checked (mostly cause I'm not sure how) are the crankshaft sensor and ECM. I've looked over alot of forums and my chilton's didn't help alot. Any help is appreciated. Also, I posted this under urgent because it's starting to cause problems getting to work and appointments on time.
PS Is there any way to test the relay to the ECM?
I pulled the IAT to take a look. Unable to get a good test. Worth replacing?
94 Ranger XLT 3L V6 4x4
martin
26
St Bruno, Quebec
1991
If you suspect a relay, you might as well just buy a new one, they're not expensive and it never hurts to have a spare.
If you have a scanner that reads live data you could see what the sensors are telling the computer, or not.
Bryotch
I'm leaning away from the relay. I would think it would be more consistent of a problem, I don't have a scanner that reads live data, is this just a code reader? I Forgot to mention that it isn't throwing any codes.
martin
26
St Bruno, Quebec
1991
some of the code readers will read live data. If one of the sensors is not sending correct information it can cause all kind of problems without setting a fault code.
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
Does the 94 still have a distributor? Moisture + cracked/leaking dizzy cap can mean bad times.
Bryotch
It does yes. I had it in the shop not long ago and the supposedly replaced it. Suppose it's worth a check though.
ab_slack
12
New Joisey
2.9L
Cloudy, rainy, I too think moisture.
Distributor cap, rotor, wires.
On my original 88 BII there was a crack in the output port of the coil. While the coil was good and worked fine, that crack (on the underside not visible when inspecting it) was causing the coil output to arc to the chassis when damp.
Son include coil in that list too
Bryotch
Coil replaced already. It seems to be more ambient temp based rather than moisture. I do have a small leak in the exhaust manifold on the passenger side near my IAT and MAF sensors.
Bryotch
Just an update, I tested the Connector pin to the MAF and am getting significantly more voltage than normal. What could cause this?
