Snow blower not running right
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I have a snow blower that ain't running right. After it gets warm, it will idle fine. But when you try to run the auger, the engine quits. The engine seems to start okay and idle okay. It's just when the engine is warm and when a load is applied. As I don't know much about carb'ed engines in general I am utterly confused. Any help is appreciated. Thanks guys.
JC 97
34
Mi.
Ford Ranger xlt
4" suspension
31x10.5
I would clean the carb.They are pretty basic.Put fresh gas in it too.
badmts
14
Lakewood Wa.
Mazda
you can turn an old DISHWASHER into a cool SNOW BLOWER just get HER a new SNOW SHOVEL !
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I gas one that would die out like that too...was going to take it to a small engine repair shop but they were backlogged...so I took the cowl cover off and as I was doing that a bolt fell into my hand...it was from the exhaust tube...put it back and the snowblower worked perfect...
These motors need backpressure...so check for loose bolts et al...they vibrate themselves to pieces...
Oh...and change the oil...must be done every 25 hours or they blow up...
mp3deviant721
24
Eau Claire, WI
2.3l of fury
I forgot to add that it's a 2 stroke, don't have to worry about changing oil but I will check for loose parts though.
I do have to change the symptoms though, the thing stalls when warm, even when idling. I was fiddling around with it before and it kept stalling no matter what position the choke was in.
martin
26
St Bruno, Quebec
1991
Check that the muffler is not plugged with carbon. Carbs are often a problem with two strokes, especially if it has one of them pump type carbs, ie. no float.
17,867
SW Iowa
Some two strokes have a screen on the muffler for a spark arrestor that plugs up and snuffs out the engine. Kinda weird to worry about that moving snow though.
Gaskets and the diaphram in the carburator can dry out in storage. There should be numbers on the carb you can look up and get a kit for. An ultrasonic cleaner and carb cleaner will go a long ways to clean up the carb.
The ultrasonic cleaner also works wonders on gun parts and jewelry too :secret:
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
Clean the plug, fresh gas, not full tank, some sea foam or mystery oil.
Keeping it running is the trick if you don't want to bugger with the carb.
I have a generator that hadn't been run in, oh 10 years. The gas was rotten, smelled horrible. I drained it, sprayed some carb cleaner in the carb, got it to run on that then new gas with sea foam, been great since. I also treat with mystery oil to save the gas. It does work, but that is another story . . .
Heh Heh
Happy Holidaze
scotts90ranger
4,375
Dayton Oregon
2.3 Turbo
Either the muffler is plugged or the high speed jet in the carb is plugged, if it starts and runs the low speed jet is fine. My bet would be on the carb being dirty. Being a snow blower it's probably a float carb like a lawnmower, should be pretty straight forward
LIMA BEAN
140
ALASKA
Move to Hawaii, problem solved.:D If it was fine when you parked it last year I would guess bad gas/gummed up carb.
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Thanks for all the suggestions, I'll have to try something here soon when I get some time off.
