shakes like hell when making right turns
Melt
Minocqua, WI
Mazda
2.5l
going to check the lugnuts cause i have one ex who might possibly be vindictive ... but if thats not it what do you guys think? I havent hit nothin hella hard, and all the tires are aired up good checked all the pressures yesteday, fairly new tires too ... it just started doing this today. Also, it shakes no matter what doesnt matter if im on the gas or coasting in neutral
the truck is a 99 mazda b2500 xcab 4cyl 5spd 2wd if that helps ... it has like 90k on it
MAKG
19
California central coast
Tie rod end, balljoint, shot bushing, or loose wheel bearing.
Melt
Minocqua, WI
Mazda
2.5l
you guys are gonna laugh .... i was drivin around with the ebrake on .... seems fine now!
MAKG
19
Then you need to adjust your parking brake.....
My vehicles won't move with the parking brake on, without a lot of conscious effort. The driveway is quite steep and I will not tolerate roll-aways.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Exactally, my B2 will not move if I have the e-brake set unless I gun it and burn the clutch...or put it in 2or4-lo and drive it, but then it makes a gawd awful grunting noise as the brakes try and grab.
Melt
Minocqua, WI
Mazda
2.5l
the pedal wasnt that far in ... i think i accidently hit it gettin out the car real quick to check somethin then drove off
