shackel flip
mongo
ok so why do you have to turn the hanger around for a shackel flip cant you just un bolt the shackel and flip it around?
im not trying it yet but wondering
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
It's the hanger that has to be flipped. The shackle is different on both ends. One side goes around the leaf spring bushing while the other sits inside the hanger.
James
mongo
so you cant unbolt it and turn it around
ILLEGALCONCEPTS
4
Pittsburgh PA
2.3 Modified
No, I don't think that would work. When you flip the hanger, it moves the shackle up in relation to stock. The rivets aren't that bad to do once you do a few. I was cutting an X in the heads with my dremel and then using the air chisel to finish the heads off and then punching them through. By the time I was done replacing my leaf spring hardware, I was amazed at how fast I had gotten.
James
slammedxonair
Vermilion, OH
91 and 00
the flip lifts the rear of your leaf springs which lowers the truck.
mongo
do you go back threw the same holes with the new bolts
and would you do this or an axle flip to drop your truck about 2 inches
and does this limmit your towing any
im new to the idea of lowering but the rangers just look better low
constant_projecttruck
London, Ontario CA
306 Ford
Yes same holes with grade 8 bolts, lock washers and nuts.
Axle flip is 4 inchs of drop.
Doesn't affect towing at all as you don't change your leaf pack. DON'T CHANGE YOUR LEAVE PACK! lol
mongo
i read that this will lose a little travle
so not as much weight
Dakota83
Lake Elsinore CA
2.8 V6
what size hardware do you use?
Smurf Mobile
Tucson AZ
3.slow
Flipping the shackle doesn't cost you travel and in most cases impoves the ride quality. Most trucks now come stock that way and all the prerunners that use leaves do the shackle flip to increase travel. I used 1/2 inch on mine, you will have to drill out the holes slightly but bigger hardware is always better.
Andrew
lowlowranger
Las Cruces, NM
2.3 EFI
what size bolts are good for this and where can i find them at?
Delta88
The Holy City of Kent, WA
2.3 L
I used 1/2" - 13 X 1" grade 8, cad plated bolts with plated, NyLock nuts with flat washers on both sides of the frame rails. I got everything at my local Hi-Strength Bolt distributor. I believe the whole shebang cost me ~$15.
