Saginaw Pump Installed!
Ranger44
23
Illinois
FORD
4.0 OHV
I used an HD replacement pump from a 1979 T-Bird. Bolted right into my 2.3's bracket. All the lines fit as well. No more whining, it steers easier, and has no problems bleeding. :D
Hardwareman
SoCal
Pics?
Allen
Ranger44
23
Illinois
FORD
4.0 OHV
Sure, I'll get some up. Give me till tomorrow.
Ranger44
23
Illinois
FORD
4.0 OHV
Ranger44
23
Illinois
FORD
4.0 OHV
I did run into one little problem. The top 2 bolts went in perfect, but the bottom one either stipped through or the hole didn't quite line up and was running along the bottom mounting flange and kept pulling back. Anyway's it holds fine with on the 2 bolts. Pulley also fits on the new pump. Whatever! Big difference!:icon_bounceblue:
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
So, did you eat the core charge or did they accept the plastic res ford pump as a core?
Hardwareman
SoCal
Hey Thanks man!
So this was just a bolt on mod?
What did you ask for when you walked into your local autoparts store?
Allen
rickcdewitt
5
nor-cal
4-0 swap
did you use your trucks pressure line or the early style someone was talking about?
Ranger44
23
Illinois
FORD
4.0 OHV
I replaced my PS pump with a new reman plastic pump. I couldn't get rid of the overly annoying whining. Bled it anyway I could find how, and still no result. It drove me to this.
I used the stock pressure line and return line.
I asked for a 1979 T-bird HD replacement PS Pump. Any engine will work.
Yes, they did take the plastic pump. The stock pumps for the Ranger and t-bird are identical. But that's O'Reilly's. I can't say the same for anywhere else. I would think if you were to upgrade from a plastic pump, to the metal saginaw for you "T-bird"(hint hint), they would take it for core. I really don't think most places would care, just as long as they had something to send back.
17,971
SW Iowa
They usually are not too picky, I even sent back my feedback distributer for a core after I got my duraspark one. I even asked first, parts guy said no problem.
I would hate to be the guy at the rebuilding place that has to sit and sort through all the oddball stuff that gets sent back and decide what is what though.:D
Thighman
California
Is the ps configuration on the 4 cylinders the same as the 6 cylinders (2.9 3.0 4.0)
Ranger44
23
Illinois
FORD
4.0 OHV
Yes the PS pumps are the same, just the brackets may differ.
metalmacguyver
Yeah, I built that.
11
4.0, 7.3
However since the crappy PS pumps are the same across the board, the bolt pattern is the same.
