#1
- Jan 3, 2009
- Reaction score
- 1
- Location
- In the Middle
- Make / Model
- Ford
- Engine Size
- 2.3
- Manual
1997 Ranger 2.3 and a 5 speed manual.
I'll list some info, then watch the video...
It had this condition when I bought it a couple months ago. I start the engine and it will idle smooth. I rev the engine, then it will idle and run rough. After a while it will return to a smooth idle. For example, the engine will idle smooth, accelerate through first gear and shift then it will run rough in second, third, and so on.
After driving about 20 miles or so, the engine runs fairly good and this problem almost goes away.
I get a P1443 code every time I drive it.
I get a P0303 about every 800 to 1,000 miles.
It has new plugs, wires, coil packs, oxygen sensor, and IAC valve.
The MAF voltage was within specs according to autozone's website.
Sprayed MAF cleaner = no change.
The fuel pressure is at 30 psi smooth idle, 34 psi rough idle, and it will briefly jump to about 40 psi when I rev it.
The catalytic converter sounds like it has a crack in it and it leaks quite a bit.
I sprayed starting fluid everywhere and found no vacuum leaks.
All of the following are in "closed loop":
I can unplug the throttle position sensor and it will still run just the same. Should the engine still rev with this unplugged?
Unplug the IAC valve = no change
Unplug MAF sensor = engine will idle, but will stall when attempting to rev. Small "blip" in idle when connector unplugged.
unplug coolant temp sensor = no change
unplug air temp sensor = no change
I have a ScanGauge II that I use, and it shows -40 when unplugging the coolant temp sensor or the air temp sensor. Both sensors read normally when connected.
Unplugging all of these caused NO check engine light.
The following video has 3 parts in it. You can watch the throttle lever to see what kind of input the engine has. The engine was shaking quite a bit in most of the video, but for some reason it doesn't look or sound as bad on tape as it does live. It's worse than it appears.
The first part is the engine cold and running in open loop. The engine actually dies in this segment and is very difficult to restart. Then I shut the engine off. The next part is in closed loop. The final part is the exhaust.
