Ruff stuff 4 inch lift
Broncojumper87
U.S. Military - Active
12
wichita Kansas
2.3 EcoBoost
Just finished installing my 4 inch lift and the way I understood it was that with drop brackets you wouldn't need camber bushings. from the way it looks though I'm going to. Am I wrong about this or could there be another issue? Everything on the front end is new bushings and balljoints. I do have the fenders hood and front bumper off is that enough to cause a noticeable camber issue?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Have you set your toe or moved the truck at all yet?
Sent from my SGH-I747M using Tapatalk 2
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
Not yet basically installed lift and lowered the truck down I figured it would settle some but the camber is pretty bad.
bmerr98
7
TN
4.0 X
Leave it better than you found it.
Roll the truck out of your garage or wherever a few feet (20 or so at least) and back in. Just coming down off jack stands or a lift will leave the front tires leaning (top out) some. Once it moves a bit things will settle to where they will be. Recheck and see if it's as it should be and go from there.
Jsommers
michigan
Your going to need camber bushings after a lift install. Your saposed to get an alignment after
Broncojumper87
12
wichita Kansas
2.3 EcoBoost
I know about the alignment but camber should really change with drop brackets at least that's how I understood it.
