Roll bar lights
exotic_4x4
ford ranger
Hey guys! got some lights on my roll bar, dont know how many watts they are all is says is HALOGEN on them i got them wired together in series, i have a regular ol' illuminated toggle switch, will this switch hold up to the lights? or will i fry it? any suggestions? everything is wired up and ready to go..just dont wanna burn my truck down cuz i got a low voltage switch or whatever.so im waiting to hook juice up to them till i get a response back on here.Here is what the lights look like.
mkpecor
black diamond W.A.
ranger 4x4
2.9
if you have a fuze in the wireing then you will pop the fuze, if you dont put one in so you dont bern up your rig. your toggle should be fine.
exotic_4x4
ford ranger
any regular inline fuse will work? how many amp do you recommend? cant i just get a power supply from my fuse box somewhere? such as a headlamp fuse? just run a hot wire off my fuse box to my toggle switch? or will that draw to much power?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Use a relay and wire it straight to the battery (with it's own fuse). This way the switch won't have to carry the load.
11
use a relay with a fused direct power from the battery, with a low amp control side direct power that is also fused, using the switch to control it.
