Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
if you can get the old one out... see what they will charge you if the old one is out... it will save them on time, which should lower the labor costs... saving some money here and there all adds up really fast...Well I found a shop to do it for $225, soI think I will let them handle it.
The bolt in has to be the biggest POS rear window design ever. I have the bolt in tooooooooooooVehicle specs (year and cab is the key here) as there are two styles, rubber seal or bolt in. Rubber seal is child's play, the bolt in is not too bad at all.
bolt in has a tendency to leak.I'll disagree with you on that I find it MUCH easyer to do a Bolt-in alone then the gasket alone.
