Replacing rear leafs
Grego
Seattle
Hello everyone,
My 2000 Ford Ranger XLT 4x4 is running on the same rear leaf packs since new.
Just turned 200,000 miles. Always carrying lots of tools for construction work, and looking to replace these springs with something heavier duty. Did some research and found my springs are rated for 1250 apiece new.
Any advice on heavier replacements would be appreciated.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Grego
Seattle
Thanks for the responses. With my truck empty, the truck sits pretty level. How much would I expect 1750 pound springs to lift the rear up? Might be a very bumpy ride also.
Any other higher quality options out there, Explorer springs?
I was also looking at Timben bump stops and new springs as a option.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah....they will suck unloaded.
explorer springs are rated lower. but arched differently. under axle normally though can be sold after market set up either way.
Hello everyone,
I read that as your running with a load regularly.
with that I would run the hd spring. you will maintain normal ride height.
if your not normally over loaded...consider a set of air bags or air shocks.
