replacement door speakers, good, better, best
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
OK, I sort of see where you are coming from but what do you call the stock speakers?
this even though has a second cone to amplify the voice part of the speaker is considered by many as a single ( single range or multi range, which is where the confusion is coming in) , Not single range as you are implying the the unit only produces, say, 1 Khz sound constantly. In this case all car speakers are multi range, no matter if it is a single to a 4 way, each speaker is able to handle multiple frequency's.
fastpakr
2,834
Roanoke, VA
That's a two way coaxial speaker.
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
Coaxial just means multi frequency, and after some reading I see where they consider a 2 way speaker one that covers all frequency's, low, mids that are usually dealt with by the woofer cone, and high's. A 3-way adds a mid range speaker to a post only style speaker assembly.
fastpakr
2,834
Roanoke, VA
Right, a coaxial speaker is designed to cover the whole range. A 2 way uses two drivers to do the job, a 3 way breaks it into three.
You went off on a left field tangent in your previous post. I never said anything about single tones? The point is that component speakers break the job into completely separated drivers that are each -single- purpose for a particular range. Coaxial speakers put everything on one assembly and are called 2 or 3 way depending on how many drivers are used to accomplish that task.
Bgunner
1,085
Western Mass.
Ford/Ranger XLT
225/70/R15
A single would be like a component unit that handles one frequency range.
That word slipped by when reading and caused the left field responce
telsar
4
Houston TX
I replaced all four speakers in my 93 Ranger:
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I haven't heard of a coaxial (a.k.a. "dual-cone") speaker referred to as 2-way (or any number of "way") myself. I've always seen then labeled as coaxial, dual cone, or occasionally full-range.
The OP's post was from a bit over a year ago, but I'll drop Pioneer as a recommendation. I put Pioneer 6x8s in both my Fords and they sound great (they're at least as loud as the stock speakers, but much cleaner sound w/good bass response). Got 'em at Walmart.
truckfan
13
I have the Pioneer speakers in my rig. They sound great and have a nice treble.
