Replacement Cats on a 1999 Ranger 4.0
RonSerling
13
High in the mountains of San Bernardino National F
ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
Ok here is the issue !! I have a 99 Ranger 4.0 and when I got it from this hack it had a ton of issues. One was that the rear cat was plugged and I have replaced it. Now I am getting an issue from the front ones in the "Y" pipe and in doing research I have found (A) there is only one aftermarket replacement from MagnaFlow for $800 and (B) Ford does not offer a new part as they state it is obsolete. Now my question is does anyone know if I can get just the replacement cats and cut out the old and replace them or am I stuck having to buy this over priced part from MagnaFlow. If you say I can just replace the cats can you tell me who sells them also ?? Any info would be a big help. Thanks
8,374
You are in Calif. so have to be careful in replacing Cats, they need to come with "Calif approved" paper work
In addition all aftermarket converters sold or installed in the state of California must bear an Executive Order (EO Tag) stamp issues by CARB (California Air Resources Board).
This new law firmly states that the California EO Number (Executive Order) must physically appear directly on the converter.
But yes you can cut out old Cats and install "approved" Cats , or have an independent muffle shop do it, they can bend and weld custom pipes as needed
Chain muffler shops generally can't/won't be able to bend and weld pipes, they just bolt in replacements parts as available
RonSerling
13
Ron I know the stupidity of the laws here !!! I went thru the mill getting the rear cats for the truck. I have the engine family number and I am looking for some place that can take the number and give me just a replacement cat !! I have a nicely equipped shop so I can do the replacement here !! I just need to find someone that has the correct parts !!!
8,374
Magna flow will most likely be the least expensive makers, still not cheap, lol
They do make universal Calif approved Cats, you just need to sort thru pipe size and dimensions
These would be cheaper than the pre-made bolt in system for $800, which is the "correct part"
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,871
Pittsburgh, PA
2.3 EcoBoost
1.5"
I had to get a replacement Y-pipe with cats for my Sport Trac last year, aftermarket replacement but it was also about $800. PA isn't as strict as CA about replacement parts but my county still has emissions testing. PA is goofy, some counties have emissions testing and some don't.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
Check out these listings! Ordered a lot of cats from these guys--never had issues with the product Not sure about California requirements tho.
This might take you to the page you need--1999 Ford Ranger, with 4.0--looks like several configs to go thru
https://www.converterwarehouse.com/catalytic_converters/converters.cfm?Make=FORD TRUCKS&YearSelected=1999&CylSelected=6&Model=RANGER
Also used HottExhaust--Here is their catalog and home page https://www.hottexhaust.com/california-direct-fit-catalytic-converter/
