Repairing Center Console
callmecosmo11
So, I loaned out my truck and it was returned with the center console/armrest on the 60/40 bench in my 96 ranger broken. Before it was tight to the drivers side seat and rotated down or up to act as a seat back for the middle jump seat. Now it is pulling away from the drivers side seat and sits on the bench and leans toward the passanger seat. Also it is very loose. I unbolted it from the seat with the one bolt, but do not see anything broken or bent to tell me how to or what to fix. I have searched everywhere and can't find a diagram or anything on how to fix this problem. Anyone have any advice or have solved this problem in thier truck? Any and all help appreciated.
Ranger Arm Rest on 60/40 seat
Hello,
Did you ever get a reply to your inquiry? I have a similar problem on my 93 Ranger super cab. I don't know the first thing about removing the arm rest to even begin to diagnose the problem. How is the arm rest removed from the left seat? Any clues are sincerely appreciated.
Bill Allen
(310) 488-6900
4x4junkie
583
So. Calif (SFV)
2.9L V6
35x12.50R15
Usually it's just the bolt itself has come loose, but if you removed and retightened it, I'm not sure. (use Loctite on the bolt, maybe it just came loose again?)
(bolt is behind a circular trim cap on the inside of the armrest compartment. T-45 or T-50 Torx IIRC)
callmecosmo11
Thanks for a reply finally. baj, if you pop the plastic cap on the inside of the console there is a star shaped torque bolt that can be removed. I tried tightening this but no luck. There is a odd shapped washer with the bolt as well. Tightening did nothing. Any other suggestions. Could the bolt from the seat have been bent or broken?
