Rear Window Seal
Broncopower33
Ramona, Ca
I have a 90 bronco ii and I am looking for a new Rear Window Seal. Anyone know if they still sale them.. I tryed LMC, Ford, and even a windowshield company.....no luck. Anymore, thanks
xr75er
7
ford/dodge/ford
2.9 stock
I would like to find new side window seal trim, any ideas on where? changed the batt teminels today. I have a nice long list of things I want to do and what I have to do. I guess the former owner put spline locks on almost all the lugs but didn't leave the key. I can get ome off e-bay but I'm trying the tire shop first. 86 b2
Broncopower33
Ramona, Ca
thanks kmc, but that is what I order already and its not the right one too. I think that is if your glass opens. My b2 has the sealed window......
Thanks anyway
Broncopower33
Ramona, Ca
thanks kcm, but that is what I order already and its not the right one too. I think that is if your glass opens. My b2 has the sealed window......
Thanks anyway
CopyKat
8
Manitoba, Coldest place in Canada
I have a couple in decent shape. I've got 3 replacement opening windows so I don't plan to have solid glass in mine anytime soon.
How much is it worth to you?
Broncopower33
Ramona, Ca
is it ez to do the swap to the other glass. I have a parts b2 with the glass that opens.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
For the quarter glass?
It isn't a seperate "Seal" it's molded to the glass
and the glass is literally bolted to the body
So the only way to replace the "seal" is to replace the
glass as an "assembly".
what exactly is you problem?
It is that the seal is looking oxidized?
Or do you have an actual leak with water getting into the cabin?
Because if you have a leak it may not be the seal, the side
windows on the bronco2's is made the same way as the rear glass on a Range supercab and all the side glass on an Aerostar, and the others all have issues with the nuts working loose over time.
So you MAY just need to pull the interior panels and retorque the nuts...
AD
CopyKat
8
Ya it's farly straight forward. I would suggest that you use threaded inserts (Rivnuts) instead of just drilling and tapping into the fiberglass.
I've converted mine and it's been fine for about 5 years now.
Broncopower33
Ramona, Ca
thanks copykat, all try it
Broncopower33
Ramona, Ca
great pics..... thanks. I have the b2 at the body shop getting painted, cant wait to get it back and try this. All post some pic when im done.
CopyKat
8
Too bad you couldn't zip the opening window hatch to them and get it painted with the rest of the truck.
Much easier to swap the whole hatch as it's all a bolt on.
Broncopower33
Ramona, Ca
I thought about that before I started all this, but the back in on my parts car is trashed, just the glass is good.. Oh well, we took all the glass out on the hatch that is on it now, so should still turn out nice.
