Rear TTB?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
So can the axles from the 50 be made to fit the 44 housing?
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
thats kick ass, you ever take it to the desert or a desert like terrian? did you put coilovers on there? do you still have it??
it was never actually completed,though i did drive it around some.it just had 6'' lift springs for a ranger front with custom buckets,and some long bds shocks.
i was building it just before i ended up moving to the islands,and it was either bring that or the big ranger...i couldn't bring everything.
so i cut it up and scrapped it.
Did the rear wheels turn at all or just fixed to go straight?
I bet a setup like that could take jumps all day.
it was set up for rear steer.some of the parts that were bought for the rear steer on this are actually in the shorty explorer now for it's rear steer.
i would imagine it wasn't rear steer... there should be some kind of hardware showing, shouldn't there?
it's there,justall tucked up between the frame rails.you can just make out a tie rod end on the left side.
It looks like the FSB guys are doing it for the easy to find stock 4:10 gears.
that makes sense...d44 4.10s can be hard to find.ironically,i'm in the process of doing a gear swap on a d44 right now-the customer wants 3.73s,the stock ones i'm removing are 4.10s.which means i now have to find a different carrier.
only if you also use the 50 outers,which are the same as 60 outers except for the knuckle.it takes a bit of fab,but i've done it a few times.
Heavyfire14
19
imperial valley
FORD
2.9L
:shok: damn... ima have to try something similar to that, but without the rear steer. thats just too damn cool
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I am going to remember this.
gwaii
2010 OTOTY Winner
66
haida gwaii
460
this is what a 44 arm looks like modified to take the 50 outers.the top balljoint is the same,but the lower is larger,as well as further down.the 'c' needs to be openned up to clear the bigger u-joint,as well.
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
I found another rear TTB setup :)
Toreadorranger
5
Sal
Found those pics I was looking for. Its the front end of two F150 frames welded together, you can see the welds in the first pic of my next post.
Toreadorranger
5
Sal
Toreadorranger
5
Sal
Bronco 2 with rear TTB.
Toreadorranger
5
Sal
That thing belongs on scary steering
That is actually a pretty well setup hydraulic rear steer for a TTB, not scary at all.
CHKNFKR
73
Illinois
545 CID
Sure both links are equal length and generally centered between the beams, however the links should be of equal length to the beams and follow the path of the beams. If you watch that video closely, he rarely lands straight and has to aggressively counter the bumpsteer. Even with all four tires on the ground you can see huge toe changes as the suspension cycles, even under acceleration and braking.
