rear main seal replacement 2.9
88 xlt
ranger
other than either motor or transmission pull what kind of job is it to remove and replace the seal? It looks different than most i have replaced?Any helpful hints or suggestions???
Clem
Yakima
2002 Ranger XLT
1986 Bronco II,
Ranger-4.0 B2-2.9
88 xlt
ranger
rear main seal
looks like I am about to get properly educated will be pulling engine soon and replacing rear main seal.front seal in tranny, and any other seal looks bad,good ole freeze out plugs.
I don't think the engine needs to come out for this. Pulling the trans should be enough.
2813josh
9
Mascotte,FL
Ford,Ford
4.0 V6,4.0
the prying method with the screws doesn't work so great..glad I had the motor out when I did mine.
SSSnakeCharmer
My B2 needs the rear main replaced too. Are there any step by step guides on how to do it?
richard booth
28
Tacoma wa
2.9 for now.
It is quite easy, I have done it twice, once on my 2.9 and once on my 4.0. just a careful pry out w a pointed awl, careful not to scratch the crank! aim the awl toward the block and tap until it gets a sufficient bite to pry it out, both times it came out easily for me. Then having a proper sized socket to tap it in with, use ample grease and it will tap in nicely.
