Rear end "Clunk"
Ranger Mike
Chambersburg, PA
2.9L
I have read a lot of posts related to rear end clunking, but none seem to be what is happening to my 89 ranger. I bought the truck to use only on occasion to haul brush or for a trip to Lowe's, but I like driving it so it is used just about everyday. As soon as I drove it home after buying it, I found the engine leaking oil onto the exhaust. I drove it like this for about a year. I recently (last week) repalced both valve cover gaskets. I also wanted to repalce a leaking rear end cover. When I removed the cover, I found out it was plastic and had a big crack in it. Over the past two weeks or so, I had noticed the inside rear tire spinning like crazy when making a tight turn to either side. It would also make a loud clunk and seem to free up on occasion and the spinning would stop. I thought that since the rear was leaking, it was just low on fluid. Today, I replaced the cover and filled the rear with fresh fluid. I just took it around the neighborhood and it is clunking just the same as it was before, maybe worse. What could the problem be? Does the rear need rebuilt? I did find some metal shavings sticking to the fill plug and in the bottom of the hosuing when I changed the cover. Any help is appreciated...
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Did the spider gears look OK? (no broken/chipped teeth)?
Any gear whine noise?
Is it a limited slip or standard differential?
Ranger Mike
Chambersburg, PA
2.9L
It is a standard rear. I didn't notice any teeth missing on the spider gears when I had it open. I did just add a little fluid a few minutes ago to be sure it had enough in it and I found lots of shavings on the plug again. I had cleaned all the shavings I could find out of the hosuing previously. I don't have a good feeling here.
Ranger Mike
Chambersburg, PA
2.9L
I forgot to mention. No gear whine.
martin
26
St Bruno, Quebec
1991
Is it in four wheel drive?
martin
26
St Bruno, Quebec
1991
Yes, but is it in four wheel drive when it is doing this.
Ranger Mike
Chambersburg, PA
2.9L
I have not had it in 4 wheel drive to see if it still does it. I suspect it will. When it makes the noise it feels like there is a cement block rolling around in the bed f the truck and banging off of the sides.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
It sounds to me a deeper inspection is needed inside the diff.
A bad spider gear could cause symptoms similar to what you describe (not all that unusual on the 7.5").
martin
26
St Bruno, Quebec
1991
Sounds to me like it's in four wheel drive.
maroon ranger
East Helena, Montana
1994 4.0L proje
Just a quick question...why does it do that in 4 wheel drive? Is it cause of the spiders engaging and disengaging or is it to do anything with the u-joints or is it cause of the transfer case or a combination of any of these? I have always wondered about that.
Mac
183
C. Wisconsin
2000
199
If you're finding shaving in there, it's not going to get better. Prepare for some work. I always liked rear ends with a magnetic drain plug in them.
Dave
Ranger Mike
Chambersburg, PA
2.9L
I will pull the cover again and take a closer look at the gears. Thanks to all.
Ranger Mike
Chambersburg, PA
2.9L
I pulled the cover again and spun he gears. Spider gears are indeed worn. One is missing tooth all together. I cannot find it in there though. What now? Is it better to just put in an entire new rear from a junkyard or try and rebuild this one? I want to keep this as cheap as possible. Thoughts?
