Rear end axle swap
viperar15
Currently I have a 7.5 4.10 in the rear of my 99 4x4 ranger. Working on swapping in a v8 and to put in a Ford 9" rearend.
I read the tech docs on shortening a dana 44 for a front, which can be applied to a rear end just as easily, but I have a couple questions before i begin cutting and having the axle shafts sent out for shortening.
does the pinion HAVE to be centered under the truck?
reason i ask is if it has to be, then i will need to buy new custom axle shafts for the ranger, because there is not enough material on the axle shafts to cut and re-spline. but if i just shorten one side or the other of the axle housing and axle shaft, then i can just have 1 axle shaft cut and re-splined since that would cut off further and give enough material for the job.
thanks!
RockRanger
7
Fresno CA
How far are you planning on the pinion being offset. A few inches probably not a big deal. if you are talking a foot then you may have issues with the gas tank or exhaust. Suzuki guys run Toy axles with an offset t case.
viperar15
after measuring everything up tonight, i would end up hacking off 2.5 inches from the left side and 3" off the right side. but that leaves me with having to buy 2 custom axle shafts (since the 31 spline was tapered past the spline, there isn't enough material 2 or 3 inches down to get it re-splined)
so instead, cut 5.5inches off the driver side (this way the pinion moves towards the exhaust, which can be modified). in this case, i would have 1 normal axle shaft and be able to send out the other for cutting and re-splining (5.5 inches puts the cut down to raw metal that hasn't been touched by a machine yet). so if i'm doing my math right, it would be off center about 3 - 5 inches.
if the exhaust gets in the way... that can be solved in a multitude of ways. :headbang:
hitech_hick
Madtown, USA
Not to over complicate things here, but what is wrong with running a Ford Explorer 8.8 rear?
hick
viperar15
because i already have a ford 9" sitting in my garage :)
viperar15
lol.
well... if i was to sell it, what you think i could get for it?
i haven't gone looking around yet to see the pricing of a used 9"
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
The stock Ranger diff is already offset 1.5" to the right (passenger) side. If the diff is 3" offset the same way, I don't see a problem. 5" I would think might cause some vibration issues though.
viperar15
alrighty... after some discussion last night, its gonna get put under the truck as is, full width with a d44 full width front. my brother talked me into it....
ok.... and NO its not gonna leave my hands for $20. lololol :p
