KornTruck2
- Mar 27, 2023
- 25
- Chicago
- Ford Ranger
Hey guys. I had to do some work to my truck, my rear wheel cylinders were leaking and destroyed everything. I had to do axle bearings and seals as well. All this stuff is cut and dry, the bearings got tapped in with a bearing setter, same for the seal. I replaced the 10” brakes setup, i replaced everything with a kit, i used timken bearings and napa seals. I do not hear the axle howling, the hub center reads at 114 on both sides. Pass side reads about 170 on the outer edge where the shoe rides. On the drivers side, its 290. I took everything apart, the l made sure the place sensitive parts are on the right side. The only thing i can really thing is the wheel cylinders, i sorta want to move them side to side. I also partially think that even all the way adjusted down, there should be more play. Is there a chance that
I just need to burn these parts in? I need help, thank you so much
