Rear Drive Shaft Removal
belovedb2
I order to change my B2 transmission I have been trying to remove the rear drive shaft by removing the bolts from the shaft to the rear axle flange. I can not get them out. One of the issues is that it has CV joints which have a steal cage and thus limit what wrench or socket I can use. Anothee issue is that when I use my air impact tool the shaft will flex limiting the impact force. Any suggestions?
ChopTop84
Carbonado
2.8
You need to get it hot with a torch. They are probably loc-tite'd into place. Also, double up your wrench. Meaning put the tightest box end wrench you can get onto the head, then put another box end wrench over the open end of the wrench you just put on the bolt. This doubles the length of that small wrench and gives you way more torque.
belovedb2
I have been trying a propane torch. Do I need a hotter torch. There is a lot of steal around the bolts which is a large heat sink. What type of torch do you use?
ChopTop84
Carbonado
2.8
oxy/acetaline with a small tip. get the bolt itself glowing red darn near all the way thru the flange.
Also, soak it all in PB blaster the night before. Its good stuff.
whocares
PB Blaster is the nectar of the gods. That is all.
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
If u use oxy/ acetylene, be careful. It won't take long to get it hot and start melting. I prefer a propane torch because ur less likely to eff something up.
BlackBII
Ranger Custom
Truck of Month
982
UT
Box end wrench and 3lb sledge. Works every time.
Or, 12pt 12mm socket with a 3ft Breaker Bar. You will only be able to get at two at a time, then you'll need to turn the shaft to get the other two.
pillen140
45
winston-salem, NC
i have noticed in almost every post by you i have read, you suggest using a hammer....... I LIKE YOUR STYLE!!!!
xr75er
7
ford/dodge/ford
2.9 stock
If you try MAP gas it will heat like oxy/acct.but not melt the steel. It's hotter than porpane. You can get it a home center stores. It's in a yellow bottle.
BlackBII
Ranger Custom
Truck of Month
982
UT
That's how I roll, brah.
#1 needed tool when owning and RBV: 3lb sledge.
:icon_thumby:
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
BFH's do come in handy. The breaker bar works too:icon_thumby:
belovedb2
Thanks. PB Blaster and MAP gas. I'll try it tomorrow.
The_Dealer
10
Macon, GA
Duh!
x2...cant go wrong with a bfh...lmao dont try that with a cheap wrench:headbang:
