rear drive shaft question. cv to non cv
shawn.m
18 miles se of placerville,ca
picked up a extended flex rear drive shaft. It is not a Carden type.
My current drive shaft is a carden custom job. It is starting to spread at the rear axle so it needs work.
any thoughts on running the NON -Carden Drive shaft? I know that I will have to change the angle of the rear axle from the current 8 degrees up to about 2 degrees up.
The CV style ones are generally considered to be junk. The double-cardan style is the preferred. I'd only use the CV as a temp until the other one is fixed.
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
I concur. My CV one just blew up on me and I promptly replaced it with a cardan one.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
I have a stock B2, but I have been running a rear drive shaft with a single u-joint on both ends for some time now. I would say it has at least 20K on it. No problems I can see or feel.
shawn.m
should have said the 2ne custom one that i have is a single u joint on each side
Junk Collector
Truck of Month
4,806
Rapid City SD
Single cardan will work fine for a stock height vehicle but I would be suspicious if it would even bolt up with more than a mild lift. I have a 6" in my B2 and a single cardan won't bolt up - u-joint angle is too extreme... even if it did bolt up it would destroy itself very quickly if the rear suspension flexed at all.
shawn.m
sorry I just realized i did the title as CV or NON CV . it should be Carden or no carden
are you talking about a CV driveshaft? yes that would not work
I have a double carden right now -see picture - if you look hard at the rear joint you can see it is spread a little bit
the new one is a single u joint on each side - lengthened to have more flex. You can see for some reason it is out of phase by 20 degrees or so. Just need to take it apart and move it over 3 teeth or so
extended
closed
Junk Collector
Truck of Month
4,806
Rapid City SD
Well technically the style you have in there now is called Double Cardan OR CV, the terms are interchangeable. The other type of driveline, with the ball bearings and stuff like a CV axle is also called a CV driveline. It is confusing.
I think your pinion angle looks like it is way off. You might be able to get away with running your single cardan shaft with it the way it is now, but you will wear out u-joints really fast unless you fix your pinion angle. That is the whole reason they use the double cardan shafts to begin with... to correct for the extreme angles in situations like this.
I think the best solution for you would be to fix your pinion angle, and have a double cardan driveline built or put one together with stuff you already have.
shawn.m
1st I got it this way and the guy wheeled it this way for 5 years.
That said, the nose looks real high. However, when I measure the angle of the nose -9 degrees. It is pointed right at the end of the transfer case, which is the point it is supposed to be at for Double Carden driveshafts.
The angle does not take into account flexy rear springs that wrap and change the angle to even more up.
I bought some 4 degree shims yesterday and going to put them in and see what everything measures out to. If it is close I am going to put in the standard driveshaft in. Then go get my double carden that is the bronco now to be fixed.
Functionally and grammatically that is the same as what you have. There is double cardan, or single cardan, but no cardan would be CV.
shawn.m
ok if you want to get technical
I have a Double Cardan drive Shaft currently. the Double Cardan Shaft acts as a constant velocity joint - this is what is currently on my Bronco.
I am looking at replacing my Double Cardan shaft with a Cardan joint drive shaft which does not have Constant-velocity abilities. So I might experience more drive line vibration because of the lack of constant velocity abilities.
the early bronco 2's came with a Rzeppa joint or Tripod joints. which also acts as a very effective constant velocity joint. However, the lack of maintenance usually doomed these joints in a hostile 4x4 environment
The original question was how much more vibration I would feel.
:thefinger:
Junk Collector
Truck of Month
4,806
Rapid City SD
Alright if you question is simply about vibration - I think you would have very little assuming your driveline is balanced, regardless of the type of joints. The CV/Double cardan is only there to correct angles. I had a single cardan type on my Ranger, the pinion angle way, way off and I had no vibration at all.
I still have my doubts about your pinion angle but let's just agree to disagree. :icon_cheers:
