Rear brakes and then some...
RJ_Ranger_Man
8
Denver
Ford Ranger XLT
Vulcan 3.0
So if im replacing my drums and pads and hardware what else should I be replacing since im already in there???
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I just moved your post to the brakes forum.
For sure check wheel cylinders and axle seals before putting the new shoes on.
RJ_Ranger_Man
8
Denver
Ford Ranger XLT
Vulcan 3.0
Wheel Cylinders and axle seals??? What would I be looking for exactly ? It's my first time and I only know what I've seen on a handful of YouTube videos but I am mechanically knowledgeable I do HVAC but that does not make a mechanic lol
Should I just go ahead and buy the parts and do them anyways since I'm in there?
RJ_Ranger_Man
8
Denver
Ford Ranger XLT
Vulcan 3.0
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Chances are those would be available local if you needed them.
Just look for leakage around the ends of the wheel cylinders. Also for leakage where the axle shaft exits the housing.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Also... pick yourself up a set of brake spring tools. They're reasonable and will make this job much easier on yourself.
Not all hardware kits come with the adjuster hardware. If you live in the rust belt... you will most likely need those.
Rangers had either 9 or 10 inch brakes. You know what size you have... and you have the right parts?
RJ_Ranger_Man
8
Denver
Ford Ranger XLT
Vulcan 3.0
OK I got the adjusters the kit I'm getting doesn't have them but I'm worried about the parts quality,because I'm getting them from amazon😒 but I'm gonna go with Dorman when it comes to brand and I'm getting 9inch but I'm not sure if that's the size but I'm pretty sure that's the right size I have a 97 XLT rear wheel 3.0 and I have the pliers already.
