Rear Axle Noise/ Movement
dogboy
14
Enumclaw/ Carbonado, WA
'93
So, yesterday I was talking to a couple of friends leaning on my truck and I wiggled the truck by the bed and I heard a clunking noise. I did a it a few more times to narrow down the noise and found it was the axles/ rear end. So, I Jacked it up and took off the wheels/ drums. I found that the axle moves in and out (like you were going to take it out), but it doesn't move up/down/ side-side. So I am pretty sure my wheel bearings are just fine. I am just wondering if the in/ out movement is bad or if it is nothing to worry about. It only moves anough to hear it and kinda see the movement, maybe a 1/16th of an inch of movement. And, both sides do it, not just one side.
I know the axles are held in by "C" shaped clip and then a pin goes in and holds the "C" shaped clips in place or something like that. Or, at least that is how it was on the 94' (I think) Explorer that I work on in shop at school.
Thanks for any help!
krugford
Iowa
That's normal. 1/16" of endplay is fine.
dogboy
14
'93
Ok, thanks guys, That's kinda what I was thinking. I was at my cousin's house at the time, and my uncle (has worked at a wrecking yard for over 25 years) said it was "no bueno" haha.
Kinda off topic, but what is it that makes some of the Explorer axles fall out while driving down the road? My dad drives a semi and has seen many Explorers on the side of the road with a wheel and axle sitting next to the rig (or gone).
I thought that play, might have something to do with that problem.
