Rangertoy's SAS lots of pics
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
Solid Axle Swap 4x4
6?
Well it has been a busy couple of months. I am almost finished with the SAS on my 99 ranger. It started out because of cheap wheel bearings, one came apart and f-ed up pretty much everything on the drivers side. It was going to cost around 2 grand to fix the IFS so I said screw it and started on the SAS. I used a D30 out of a 96 model XJ. I then started striping my 90 model Ranger, which had a 6 inch skyjacker lift on it. I used the upper coil mounts, coil springs, shocks, steering head and the rear blocks from it. then I started striping the 99, it was a long very educating experiance. Heres some pics, be easy on the critisizm. Some things like the Y-liinks will be re-done when people start drinking more milk, I work on my inlaws dairy farm and times are tough right now.
before
everything taken out
cleaning up the frame
a pile of parts
front end under truck
coil mounts welded to frame
sitting on its own weight with rear lift on
y-links done
hard to see but its the track bar
on 36 inch TSL radials, and painted
Don't worry about the 90 model, when I get some more time I have some
D60's amd a 351C 4V going in it.
COPPERHEAD85
41
west tennessee
302
Looks like you did a hellava good job to me.
rngr4x4beast
riner va
nice man i hope mine turns out like that when i start and finish it
Chance
RIP - 10/7/2010
13
Roseburg, OR
Looks good... I am looking forward to/dreading the day that I start mine... but 4th gens just look sooo good sas'd
Rangerman4158
Blue Ridge SC
Nice job! where did you get your front bumper?
Downey
Muncy, PA
i guess i dont understand but why did you need a track bar with the y links?
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Y link is still a radius arm setup, and only 2 links square to the frame means you need a third to keep it parallel and keep the axle from sliding around under the truck
Downey
Muncy, PA
^^^ thats link what i thought but wasnt sure
Fx4wannabe01
February 2010 OTOTM Winner
20
Boring, Oregon
What all is left? Engine crossmembers? Steering tweaks? How'd you mate the 98+ steering shaft to the new box?
I really like the height....Not too big...not too small. Just right. I plan on building mine to clear 37's just fine on full widths, but running 35's. Trying to keep CG down a little bit. My buddy's got an 07 Ranger on 40's....TOWERING 40's. I have a feeling I'll get a text of it on it's roof this winter. :(
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Looks pretty decent!
One thing I can point out is that it looks like you don't need the dropped pitman arm on there anymore. You want your draglink to be at the same angle as your track bar so it doesn't bump steer.
Chance
RIP - 10/7/2010
13
Roseburg, OR
:huh: oh now I better finish mine before yours...
(I'm also curious about the steering shaft)
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
Solid Axle Swap 4x4
6?
Chris at White Rhino Fabrications made it for me earlier this year. I am tossing around the idea of selling it.
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
Solid Axle Swap 4x4
6?
Steering shaft- I took the 99 model shaft cut it just below the cv joint, the took a 90 model shaft and cut the "rubber bushing" end (the end that goes to the box) and had a good friend at a machine shop weld them together. I will get some pictures later on today.
AlwysBusted96
Oregon
Mazda
Looks good. Was it a budget build of sorts? Thinkin of doing mine but money in an issue at the moment, plus its my dd
rangertoy
Firefighter
EMT / Paramedic
ASE Certified Tech
Bay Springs, MS
Solid Axle Swap 4x4
6?
I probably have $1500 in it
  • ZMan
