rkneeshaw
- Nov 9, 2009
- 7
- Northern Michigan
- Ford
- Engine Size
- 4.0L
alright, I know this has been covered a million times. Get a fat girlfriend, its so the rain can roll off the roof, its the weight of the fuel tank+battery+driver, etc.
But this is what doesnt make sense to me: The truck sat level when new right? These things dont come off the assembly line with a lean. So there has to be a cause that I can address. Something is worn, or something is binding.
I just replaced the rear leafs, rear shocks, front springs, front shocks, and the truck still leans to the drivers side, about 1.25" lower than the passenger side (without a driver in it). I'm trying to possibly imagine what else can cause this. Thoughts so far are:
* Body mounts - odds of this being the cause seem slim to me, all of them on the left side would have to be bad... plus the truck bed itself doesnt have "body mounts" to wear out, so if the body mounts were bad I should be able to see a noticable bend or misalignment in the body lines of the truck, which I dont
* sway bars/sway bar bushings/end links - Is it possible that they are old and unlubricated causing binding of the sway bar that keeps one side of the truck lower than the other?
And thats all I got. I can't imagine anything else in the suspension that could possibly cause the lean.
Agree? Disagree? I'm thinking I'll disconnect my sway bars and see how it sits. I'm also considering loosening the leaf spring bolts, bouncing the truck a few times, then retightening with the weight of the truck on the springs.
Any other ideas?
Any other ideas?
