Ranger 92' project from quebec city
rotoranger
Québec, Canada
hi! there some pictures of my truck at the beginning, when i buy it. the spring after, i install a 4" lift kit from rough country and take some experience with the truck and take the time to feel it in the trails.
stock truck
lift kit install
new tires and first trail!
body shop ;)
2 day after body shop:)
2 week after body shop :(
and this summer broken parts
and at the end of the season, my girlfriend's little photoshop
86 slo-vo
02/2011 OTOTM Winner
36
owensboro, KY
the truck looks pretty good, whats the plans for it?
rotoranger
Québec, Canada
this summer when i broke my transfert case output shaft i try to built 1 with 2 cause i didnt find a t-case with 2 yoke for the output shaft, the front was always a slip yoke, so i take a 1350M and a 1350E (or 1354?? i dont know) and drill the case to install the shifter in the electric case. it was complicate but it work! i drill it with my co-worker on a milling but during a mud drag the t-case beging to snap gear in compression and finally somethings happen and i lost the front wheel drive. i didnt open it yet to see whats happen because i finally find one with 2 yoke output shaft.
this winter i plan to install a dana 44 from 1969 bronco. i check the page of UrbanredneckKids build thread Kyle M and josh40601 and i really like their fabrication, you work greats guy! your job are good models for me!
but i wan to know, i wan to replace drum brake on the d44 and i have a ttb from f-150 1985, does the knuckle could fit? its the only part of the swap i didnt understand well , sorry i'm not a perfect english man!
thanks for watchin and comments!
rotoranger
Québec, Canada
if nobody knows if it fit i will try it but if someone say, it will not fit i wan spend my time on something else
rotoranger
Québec, Canada
many things if i have the money and the time
d44 swap, 1 piece driveshaft, engin clean-up and maybe something to kick-ass the 4.0L :D
sohc86-06
April 2011 STOTM Winner
MTOTM Winner
1986 2wd ranger
ford ranger spo
man truck looked good an seem to work quiet well keep us updated on the build
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
Baby Ford... nice:D
04sd
'90 / '84
4.0 / 4.0
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
Dude that sucks big time. But I do like the 92. The gray photo shows you put a lot of work in it. :icon_thumby:
rotoranger
Québec, Canada
BTW, '69 Bronco's had dana 30 front axles.
yeah but i check tube diameter, axel and few things and they are the same? is it the gear that are smaller?
they use the same u-joint
the only thing that i see it theres no ball joint, its king pin
gearhead51
Fitzwilliam, NH
D30 has a plate with 4 bolts on top of knuckle, d44 has one bolt in the middle with a castle nut on top of knuckle. It's possible the original owner swapped in a d44 out of a newer EB
rotoranger
Québec, Canada
so the only difference is the king pin vs ball joint??
