bhawk
- Jul 18, 2008
- 0
Just finished installing LH radius arm bushing on my son's 94 ranger 4x4. I thought I'd share my experience for the benefit of others. There are 2 methods to get the bushing off the shaft. The service manual tells you to remove spring, shock, sway bar, tie rod, and loosen axel pivot bolt, then pull axle assembly forward and radius arm will come out of braket. I tried, but couldn't get the axle forward enough. So, plan B.
Removed all bolts holding radius arm bracket to frame and cross member. But 2 rivets remain. I ground the heads off the rivets with my 4 inch grinder, but I could not pound them out. Can't really get a good swing with a hammer under there. Tried air hammer, no go. Here's what works.
Grind head off both rivets. Get chisels between the braket and frame and wack them into the gap. The bracket will pop off fairly easily. Then grind the rivet down flush with the frame. Try and punch the rivets in with hammer, but not likely to go because those rivets were put into the frame and bracket while red hot, and they almost fuse to frame. After rivet if flush to frame, drill center of rivet with say 1\8 inch bit. Go only as deep as the thickness of the frame. Then widen the hole with a 5\16 bit, again going only as deep as the frame or a tad more. Then put a punch into the hole and pound away. Rivet should brake loose easily now. The holes are 12mm wide, so a 7\16 bolt is a bit loose and a 1\2 inch bolt won't fit. But it is very easily to widen the holes to 1\2 inch with your drill. Use grade 8 bolts and install away. I believe the problem with removing the rivets stems from the heat they used to install them, causing them to fuse to the metal and even mushroom out a bit in the gap between the radius arm bracket and frame. Best thing about bolts is it will be so easy next time to replace a bushing.
