radius arm brackets?
fenton mudder
My 2wd 94 ranger has rough country 1.5" Leveling coils. The problem is that now my camber is off and i wear out the outside edge of my tires, and i found brackets on jc whittney to drop the radius arms down and that will adjust camber. but their 210.00 dollars and i was curiuos if this is the best way to deal with this problem or am i missing something. Thanks.
F150hybred
Arborg Manitoba Canada
Your idea is a little skewed. Camber is the leaning in or out of the tire. Radius brackets will not correct that issue. The part you need is actually camber bushings. They are available at almost any auto parts stores. If you take your truck in for an alignment at a COMPETENT alignment shop, they will be able to "straighten" things out for you. The bushings in question are only about twenty bucks... a far cry from the two hundred some odd that JC wants.
If you want to do your homework and maybe some of the labor yourself, a company that makes some real good bushings is specialty products. (link posted below)
http://www.spcalignment.com/
