quick question on a d28
'95 ranger
09/2013 STOTM Winner
MTOTM Winner
45
Lindale, Tx.
Subaru, FORD
2.5, 2.3, 4.OH
can i swap it out on a 1st gen ranger for a d35? and if so how much will it cost me?
kunar
131
Toledo, Ohio
5.8l
should be a bolt in swap. just change your front drive shaft. it will only cost you whatever you have in an axle and drive shaft (around here, less than $200) just make sure your gear ratio matches your rear.
'95 ranger
MTOTM Winner
45
Lindale, Tx.
Subaru, FORD
2.5, 2.3, 4.OH
sweet dude thanks, will it work well with the tcase?
mhughes165
9
302
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Well, if you use your stock transfer case (1350) you will have to shorten your front driveshaft 1 inch. If you use a 1354 (they are hard to find with manual shift but I just found one) you can use the D35 driveshaft assuming your transmission is an A4LD or an FM146.
'95 ranger
MTOTM Winner
45
Lindale, Tx.
Subaru, FORD
2.5, 2.3, 4.OH
what about where to find one i kno that i can just root around in a junk yard but is there a website that i could find one?
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
You could try car-part.com
I am not sure if they list small things like driveshafts or not though.
mkpecor
black diamond W.A.
ranger 4x4
i just put in a d35 in my 88 ranger, and its as easy as 4 bolts. radius arm nuts, pivit arm bolts, it took me not even 2 hrs. easy.
Jspafford
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
If someone has never done that before, or even if they have and the truck is old and rusty I don't think they will be able to do it in under 2 hours.
I would start on a Friday evening and plan for a whole weekend.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Exaclty what I did, Except had to put my D28 in my dads ranger and I had to install a locker, eclip eliminator and some other BS, give yourself extra time for unexpected BS.
'95 ranger
MTOTM Winner
45
Lindale, Tx.
Subaru, FORD
2.5, 2.3, 4.OH
yea this thing has been sittin in a field for like 10 years so im expecting the worst
