question on clutch line on a 89' 5 spd
85DANGERanger
franklin, in
im trying to push it into the slave cylinder, but it wont stay in there. its not in there tight and it leaks. its a brand new slave cylinder. what is the problem?? is there more to it then just pushing it in?? am i missing a piece?
AllanD
135
East-Central Pennsylvania
1987... sorta
'93 4.0
What kind of slave cylinder?
Plastic or aluminum?
The '88-92 Rangers are supposed to use an aluminum slave cylinder
with either a Red or Black coupler.
the '93-up "plastic" slave cylinder uses a yellow or "gold" connector
and this is not compatible with the earlier line.
AD
7.5L_STX
73
Up Dere In Da U.P. EH!
unnecessary
theres a little pin you have to drive in after the line is pushed in to the slave cyulider.
85DANGERanger
franklin, in
AD
i guess i should say its a bronco 2. it has the black connector.
85DANGERanger
franklin, in
i forgot to mention its a 89 bronco ii, your refering to the mazda 5 speed i believe.
85DANGERanger
franklin, in
unfortunetly i didnt install the slave cylinder, hopefully its the right one.
AllanD
135
1987... sorta
'93 4.0
Presuming that the line has a black connector also (they fade to a purplish color)
the compatibility issue I mention isn't your specific problem.
However you should look up inside the female coupler to see if the
barb teeth that retain the male couple are missing or bent.
AD
85DANGERanger
franklin, in
AD
i looked in there, the barbed teeth are still there but they do look pretty flat.
