Question about welding
jeffminsc
Rowesville , South Carolina
2.3L diesel
hey guys, I was welding a bumper on my car trailer but I keep getting holes in my weld bead. I'm using a MIG welder with solid wire and mix gas (75/25) I am using an old hunk of metal that I had laying around. I think it must have a galvanized coating on it because it is not rusty and has been sitting outside. I ground it down to shinny metal before I started welding it. I hope someone can give me some advice because I sure am :icon_confused:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Tiny holes like bubbles in the bead?
That usually comes from contaminants on the metal you're welding (rust, moisture, paint, dirt, grease/oil, etc.), or your shielding gas isn't shielding the weld correctly (insufficient flow, or the wind blowing it away while you're welding).
Are you welding outside in the open?
jeffminsc
2.3L diesel
Yes like bubles in bead. I Have 30 cfm going and welding inside guess I didn't clean the old hunk of metal good enough. Its been a while since I welded so I might be the problem.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You do NOT need 30 cfm when welding inside....15-20 is more than enough
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
Check the torch assembly. Make sure that everything in the gun is properly setup, and that the hose is properly seated into the base unit. I know I was getting porous welds for a bit and I couldn't figure it out. The hose had actually pushed itself out from sealing inside machine just enough to cause the gas to leak out inside the machine.
jeffminsc
2.3L diesel
Thanks for the advice. I turned up the CFM's to try and get a better weld i usually don't have it that high. I will check the lead to make sure nothing is wrong with it. I didn't think of that. I'll do that this weekend and we will see what happens.
yyc_tbird_sc
Firefighter
EMT / Paramedic
6
Calgary, Alberta
What kind of welder do you have? I have a Millermatic 211. The clamp that holds the torch assembly into the machine needs to be really tight...like almost to the point of needing pliers to loosen it.
jeffminsc
2.3L diesel
have a holbart 140 finshed welding today I guess it was not clean enough I cleaned the metal beter and no problems.
99_3.0
Glenwood, MN
4.GO!
Rule of thumb with GMAW is that the metal can't ever be too clean. With SMAW its not as big of a concern but still important. The cleaner the base metal the easier it is to get a high quality weld.
Destroyer000
January 2009 STOTM Winner
MTOTM Winner
8
Plattsburgh, NY
1999
4.0. 4.0 Supercharged
check the polarity of your leads. its different for gas welding vs flux welding.
ecenur
Make sure that your mig weld is set up properly, if you haven't been welding for a long time do a couple practice routines until you get back on track with it. Also, make sure that you have a certain amount of gas to keep the weld clean.
that_one_guy
The end of the Oregon Trail
You can actually have to much gas. 30 cfm is a little excessive for inside in a controlled environment.
94xcab4x4
Bismarck ND
RIP 94
chevy cc 4x4 15
6.0
Just like said before you can have to much gas. Also check for leaks. Im a :icon_welder: by trade and when i have used wire machines in the field i have run into quit a few leaks. Also that galvanized stuff can be tricky to weld it is some times looks like it is all ground off but isn't.
