Question about a plug under the master cylinder
BOSSC351
De Kalb
Ford Bronco II
I just fully rebuilt my sons 2.9 in his 89 Bronco II. I have everything installed and it just turns over and won't fire. Only issue I can find is a female plug directly under the master cylinder that I cannot find a male counterpart. Anyone tell me if theirs is empty or what goes there.
8,370
Master reservoir fluid level switch plug in?
If manual trans can be unused NSS wires
Make sure ground strap from head to firewall got hooked back up
50/50 test
spray gasoline into the engine, crank it
If it starts and dies then no fuel injectors
If it doesn't start then no spark
Test coil for 12v key on, AND......12v while cranking, actually 9.5-10.5v but should have voltage
BOSSC351
De Kalb
Ford Bronco II
Strap is there. Coil is firing. I get an arc from coil wire and plug wires. Fuel is firing. Plugs have a fuel smell.
On the wheel well there are multiple harness plugs. The plug closest to the engine under the master cylinder is empty. I am betting this was empty before because I have no other harnesses left to plug in.
I worked on finishing the assembly yesterday and the last hour trying to get it to start. I think I may be 180 out. Im going at it again after work.
BOSSC351
De Kalb
Ford Bronco II
Im at work so I will post some this afternoon.
BOSSC351
De Kalb
Ford Bronco II
I figured it out. I was so exhausted I put the dist in 180 out. Runs like a top!
mperry
Springfield, OR
Thanks for the update and congrats.
Happens all the time... or someone will get the cam timing off.
